Rapido 250 TMX 35MM
skidmark
Rapido 250 on a TMX 35mm carb with a breatheasy airfilter, JL 3
290 main jet
57 needle on top clip
20 Pilot
runs fantastic at high speed, although can be a bit sputtery sometimes, she can run fantastic then when I stop to fill her up, she can then run s**t, although I think this could be caused by the air fiter hose having spitback fuel in. :| so maybe too rich on the main jet.
anyone else running this set up and what jetting are you using? :?:
