Can you?...Side casing / end plate query
lockman69
Can you use a Li end plate and Li side casing/kick start with a GP2 engine case?
Will it all bolt together and work or is there some modification required?
Cheers.
gear end plate must match the main engine case ,you dont say if the kick start ramp is on the end plate or not .
you can either cut the ramp off the end plate and use the one on the side case or remove the one from the side case and use the ramp on the end plate everything elce as long as you use li clutch top plate with the little thimble thing the li side case will fit if you so wish but a gp side case is probbably a better bet
