gearbox advice
rbgaz
hi wanting to change the gearbox and exhaust on my rb as had enough of a high reving really loud thing !! going to get a rt kit when i can aford it ,
so this is what i hav now gp200 with 18x47 nk race exhaust
any suggestions as to what i could change this to to get a low reving motor for motorway use ?
cheers gaz
soullad
Just changing the gearbox alone probably will not help you much, you'll just struggle to stay in the powerband and the scoot will labour. Try changing the exhaust, to one that helps produce peak power lower down the rev range, as well as the gearbox. Such as a Taffy MK4, JL3 etc.
