Page 1 of 2
li/tv kickstart shaft?
Posted: Tue Mar 23, 2010 10:45 pm
by scoothappy
What's the best kickstart shaft for a tuned tv200? i keep bending my indian ones! :evil:
Re: li/tv kickstart shaft?
Posted: Tue Mar 23, 2010 10:49 pm
by Doom Patrol
An original one for sure. You should be able to pick one up easily enough.
Posted: Wed Mar 24, 2010 4:40 am
by scoothappy
which dealers? :?
Posted: Wed Mar 24, 2010 3:03 pm
by Doom Patrol
Well, you might strike lucky and get an old one off a dealer. Otherwise a parts fair or the dreaded e.Bay. They often turn up there and can be had quite reasonably. Be prepared to have them re-chromed however.
Posted: Wed Mar 24, 2010 8:19 pm
by scoothappy
Hey doom
im talking about the kickstart shaft not the lever. it keeps bending between the case and first gear. hope that makes sense. im wondering if there is a good upgraded one for a tuned (higher compression) motor?
Posted: Wed Mar 24, 2010 8:43 pm
by mark
believe dactek make one
Posted: Wed Mar 24, 2010 11:54 pm
by Doom Patrol
Whoops! :oops:
Feck me. You're bending the actual kickstart shaft? What are you doing to them? :shock: :shock:
Posted: Thu Mar 25, 2010 3:02 am
by scoothappy
bought some indian ones years ago that seemed good but recently put them to use and they aren't. i've bent two. one on my 185 wiesco and now one on my tuned tv 200. getting to be a real pain. :evil: so i thought there might be some alternatives. :?
Posted: Thu Mar 25, 2010 3:07 am
by scoothappy
i've seen those and they look baadasss. but maybe overkill for what i need. and loads of cash too! :oops:
Posted: Fri Mar 26, 2010 12:33 am
by wack 63
Do you lean the scoot right over to start? as this is what's probably bending the shaft as it hits the casing stop.I've only seen this once on an extended one for a 6 plate clutch and mate always leant scoot over to start.
