TS1 carb
ts200
has anyone tried one of these 30mm PWK carbs on a ts1?
they are only £80 seems to cheap compared to the others.
found it on the justLambretta site
The guy who owns justlambretta is a member on here so he will probably answer all your questions...Scooter parts seller...Scooter rider.....corrado
They're decent carbs, made in Taiwan I think, but copies of Keihin. Main thing with them is to change to European sourced jets and not the ones that come from the far east.
Special X
Is that a "coming out" avatar Martin? :lol:
ts200 wrote:has anyone tried one of these 30mm PWK carbs on a ts1?
is it a straight 30mm or a 28/30mm oval bore :idea: i run a oko 30mm this has the larger spigot of 39mm the 28/30mm has a spigot size of 35mm mine is run out of the box no changes to how it came and that includes the main jet runs well and very responsive good on fuel as well i can get around 85 miles from a tank thats not thrashing it though
i have used a piece of hose from a land rover for the rubber this gives me some extra clearance( 40mm at the biggest point)
my carb can be bored out if needed to 34/35mm
