Dead lammy
Posted: Fri Mar 19, 2010 7:56 pm
by matt 73
Got the lammy out today intending to give it the once over change of oil etc then get out for a blast. Guess what dead as a doorknob no spark!. Been in the shed a few months was running lovely for the last three years, Checked the obvious plug ht cap, lead then left it. Got a new cdi/coil unit at work cant try that till next week so whats the most likely culprit. ,Thanks matt
Re: Dead lammy
Posted: Fri Mar 19, 2010 8:37 pm
by Dazza
I'll start the bidding with ---- Low tension Coil --any more offers??
Re: Dead lammy
Posted: Fri Mar 19, 2010 8:49 pm
by Monty
disconnect the green to the loom from your CDI, in case your cut out or ignition switch is faulty
Re: Dead lammy
Posted: Fri Mar 19, 2010 9:32 pm
by matt 73
tried disconnecting the green wire already, not the kill button.Going to try cleaning up all the connections and engine earths tomorrow as i cant get my head round the fact that it was running ok when i put it away. Ah well the joys of lammy ownership
Re: Dead lammy
Posted: Fri Mar 19, 2010 9:37 pm
by Dazza
Thats why my money is on the LT, i've been out for a good thrash on mine before, next time out wouldn't start - eventually found out it was the LT coil - not the first thing I changed as you would expect
