Page 1 of 2
no spark saga!
Posted: Thu Feb 05, 2009 3:30 pm
by scootjohn777
Hi all,
I hope someone can help me before I buy a gallon of unleaded and a box of swan vestas!!! :( I have a g.p. 225 I bought a stage 4 top end from one one of the big dealers complete with crank, bearings,seals,30 mil dellorto and a revtour exhaust and all the gearing and bit's to completely rebuild including new engine casings, I've also replaced the flywheel with an af one and stator plate is a bgm one. I've had quite a bit of grief with it including an oval af flywheel,But I thought it was sorted but while on a run last sunday it died! It turned out to be the stator so I replaced it with a 120w bgm one, But I can't get a spark when I connect the cdi!
It sparks ok from the green wire from the stator(with or without the loom wire connected)
I've checked that all the earths are ok.
checked with a digital meter the red cable from the stator which read 112
checked the green cable from the stator which read 480
does anyone think the pick up could be faulty even though the continuity test shows it's ok?
Thanks All
John
Re: no spark saga!
Posted: Thu Feb 05, 2009 3:43 pm
by tony
Have you got another cdi to try mate? Thats what I would do first.
Re: no spark saga!
Posted: Thu Feb 05, 2009 3:51 pm
by scootjohn777
Hi Tony,
Yep! tried that now, with 2 and still the same!, It's mind boggling! well for me anyway! lol
all the best
John
Re: no spark saga!
Posted: Thu Feb 05, 2009 3:55 pm
by Andy Pickering
Had the same no spark problem after re build,green sparking but nothing from CDI, Turned out to be faulty CDI new one in fired straight up..I would try that first matey.. :P
Re: no spark saga!
Posted: Thu Feb 05, 2009 6:53 pm
by martinr
are you sure the wires are plugged in the right way around on the cdi. ive just done this on my imola engine followed the colors on cdi but they where wrong ;)
Re: no spark saga!
Posted: Thu Feb 05, 2009 7:18 pm
by scootjohn777
Hi Martin,
It was running ok up until last sunday but the stator packed in so I put the bgm one on and the colour code should be the same white then red followed by the 2 greens, it's driving me mad?????
thanks
John
Re: no spark saga!
Posted: Thu Feb 05, 2009 7:27 pm
by firekdp
Hi John, was the stator you replaced a BGM one? I'm sure I've read somewhere about pick up alignment issues between AF flywheels and BGM stators. I think it was on the LCUSA site, perhaps MarkH on here may know.
Re: no spark saga!
Posted: Thu Feb 05, 2009 7:58 pm
by scootjohn777
Hi
no the other one wasn't a bgm but looking at the two of them placed together the pick ups look to be in the same place? I wonder if I should change the pick up though? even though the continuity test say's it's ok?
all the best
John
Re: no spark saga!
Posted: Thu Feb 05, 2009 8:14 pm
by Andy Pickering
scootjohn777 wrote:Hi Martin,
thanks
John
Do you definalty know it was the stator that packed up :?:
Re: no spark saga!
Posted: Thu Feb 05, 2009 10:31 pm
by J1MS
Tipex the magnets that are crossed over (fire the pick-up) and on the side of the pick-up (to line-up with the corresponding laminates that protrude from the pick-up). this way when you replace the flywheel the tipex marks on the side of the pick-up will line up with the crossed over magnets. if they are out of line, that could be your problem. Hope this helps  8-)
