60mm crank with monza/ts1 for torque?
mickdale
starting building an engine with a mec 60mm crank and after torque rather than high revs/peaky hp
was thinking along the lines of a manza or ts1
should i leave the kits as standard or is there anything i could do to increase ridability?
(havent decided on pipe)
cheers
mick
or is classic rapido/tm24/ancilotti the way to go
you could do far worse than the ts1 with 1mm off bottom of barrel as per MB,s touring tune..........
mickdale
can you still take 1mm from the base of the cylinder with a 60mm crank?
cheers
mick
