225 rapido classic oko 30mm carb?jetting
paulski
has anyone used or knows someone who has used a 30mm oko carb on rapido 225classic. its through a ramair on an elbow and a af fresco pipe.and 60mm crank so 230cc. just want to no best neeedle/main/pilot? etc. struggling to get midrange spot on with jjh needle . tried 118main/ 48pilot/needle 3rd notch, but on letting throttle off from midrange cruising engine seems lean on returning to idle? couldnt get any joy with 28mm phbh in same area of setup either . any ideas please.
chris2470
Hi Paulski
I run an open mouth ScootRs 30mm OKO on a Mick Abbey Tuned 225 fitted with a MB Devtour and have it just about right.
Main 130
Pilot 40
Needle JJK 2nd Clip.
Air Screw 1 turn out.
Hope this will be some help.
Best Regards
Chris
