Lights probs...AAHH
Right rebuild grinds to a holt...LIGHTS...powered by battery charger, switch on charger no turn of ignition, brake light/ horn work..voltmeter (AC) reading 9 from BROWN/BROWN PURPLE/BLUE but nothing anywhere else.... switch ignition on NOTHING works.. and no readings from brown/brown purple/blue..wiring checked a number of times and correct and as before stripdown...earthed down frame to horn and handlebar plus rim...ignition checked and no wires hanging out...could this be the charger which is 4 amp..? loom (simple loom)....? GP200 12 VOLT
where have you plugged the charger in ?
best to be on the feed wire from the regulator, then you're checking for DC volts in the circuits. the horn will sound crap, but it should make a noise.
otherwise, something is shorting to earth somewhere, so recheck that with your multimeter
byron wrote:where have you plugged the charger in ?
feed to reg..dc volts -9
Right ..after a bit of playing feeds now reading 9 DC volts and working as should...put the black croc clip of charger to the frame stand its stood on and that seems to giving a better earth...horn/back light/brake light/festoon/speedo bulb all working...but no headlight, reading 9 volts DC from clips that hold bulb in but no headlight...its one of those halogen bulbs that your not supposed to touch so maybe no good after winter storage in a box...defo not blown either filiment.
Lam46 wrote:...but no headlight, reading 9 volts DC from clips that hold bulb in but no headlight....
check the earth the other side of the bulb then.
Lam46 wrote:Right ..after a bit of playing feeds now reading 9 DC volts and working as should...put the black croc clip of charger to the frame stand its stood on and that seems to giving a better earth...horn/back light/brake light/festoon/speedo bulb all working...but no headlight, reading 9 volts DC from clips that hold bulb in but no headlight...its one of those halogen bulbs that your not supposed to touch so maybe no good after winter storage in a box...defo not blown either filiment.
It's quite posible that your charger isn't man enough to power the headlamp, try the lamp directly on the charger.
    Users browsing this forum: Semrush [Bot] and 8 guests
