S2 wiring..Purple?
Posted: Mon Mar 15, 2010 9:08 pm
Finally got my 1960 S2 Li 150 Imola 186 put together and working But after putting a new loom in to suite the 12v conversion I am left with a purple wire from the handlebar switch...(loom has black, green. brown and pink )
I looked at the wiring loom on it before 12v adaptation (very crude) and the purple fed into the brown and pink into the regulator...So I have fed it into the brown at the headset...result no festoon and no dip....What does the purple wire do and where can I connect it to
