Circlips and bushes
davidblythe
when using a bush to step down from 18mm to a 16mm gudgeon pin what do people do re circlips
didnt think about that before i bought the bush :roll:
J1MS
davidblythe wrote:when using a bush to step down from 18mm to a 16mm gudgeon pin what do people do re circlips
I used to make bushes for the 18 down to 16 to fit the Suzuki piston and lambretta conrod. and I would leave a lip on one end of the bush so the Gudgeon pin was captive inside each bush, then the circlip only had to hold the bush in place. thats how they are usualy made.
top hat design........... :D
davidblythe
I hate it when i am being stupid, but if there is a lip on the bush to retain the gudgeon pin, how do you get the gudgeon pin in, in the first place
the retaining lip is actually internal i think
davidblythe
Worked out how JIMS bushes work now
hope there is an internal lip on the ones i have bought
