Enlarging exhaust port on standard cylinder
Posted: Sat Mar 13, 2010 11:58 pm
by rakki
I have a standard spanish cylinder, two-ring Asso piston and Clubman exhaust. When inspecting the matter I found out that the exhaust port on the cylinder is quite a lot smaller than the opening of exhaust manifold. Should I just enlarge the port so that it matches the manifold or aim for some other dimensions or just left it to factory specs?
Re: Enlarging exhaust port on standard cylinder
Posted: Sun Mar 14, 2010 10:38 am
by mickdale
i would blend the exhaust port to match the manifold, assuming the gasket will match also. i wouldnt touch the cylinder port shape at all though
will improve exhaust gas flow
Posted: Sun Mar 14, 2010 11:00 pm
by rakki
Here's the current situation in psychedelic colours.
So you suggest that insted of opening the exhaust port in the cylinder to match the shape of the gasket (whitch is matched to manifold) I leave it to current state and just bevel the port so it opens gradually towards manifold?
Posted: Sun Mar 14, 2010 11:15 pm
by sean brady scooters
just my opinion matey...but i would give your motor a 36mm power stroke at least.........
that is ,top of barrel to ex port opening..........
Posted: Sat Mar 20, 2010 9:44 pm
by e_9111
