TS1-200 Yamaha info req.
TS1-200
I`m about to check for wear on my Yamaha IT175 pistoned TS1-200, to check ring wear what sort of ring gap, when I put the rings in the cylinder should I be looking for as normal, so I can tell how much wear there is on the rings, and whether they need replacing, assuming there is no other obvious signs of wear.
Keep on keepin on
