Opened up an old Indian GP engine and found this......
.....cheeky little spring loaded chain tensioner:
dapper
Mounted on the wrong side of the chain too. That must have been under some pressure :shock:
Lamaddict
Seems like a clever design to me and I always thought that the chain ran backwards, if so this would work better. :?
Ian Hepworth
I found one exactly like that in my kelvinator avanti engine. I thought it was just a clever bodge but it's exactly the same as yours.
joespeed
this tensioner look like a massey ferguson 23c timing chain adjuster,when the chain wears the piston/pawl pushes out further,it is made in india,good idea but when the chain wears to excess the plunger will fall out possible locking the clutch crownwheel not good!
regards
joe
honestbob
thats the same way one on a trials bike works the chain is tight on top the slack wuld be at bottom
Knowledge
joespeed wrote:this tensioner look like a massey ferguson 23c timing chain adjuster.....
regards, Joe
Joe, You seem to know a lot about tractors.
I used to like tractors. I'm an ex-tractor fan.
Martin
RinB
regards, Joe
Martin at least you live in the right part of the country for tractors :frog:
joespeed
regards, Joe
martin, i like it ! not a lot,keep pulling your wire! or should that be cable ,lol
regards
joe
ps.wanna buy a tractor?
    Users browsing this forum: Google [Bot], Semrush [Bot] and 8 guests
