Fork links
Posted: Thu Feb 18, 2010 3:52 pm
by des
Will these Evergreen fork links work with Li series 3 standard drum hub.
Re: Fork links
Posted: Thu Feb 18, 2010 3:56 pm
by sean brady scooters
no
Re: Fork links
Posted: Thu Feb 18, 2010 4:00 pm
by Stampede
no, they´re for a disc brake, you have to use the standard fork links for drum brakes... they have a peg on the righthand one, not a slot as those in the picture...
Re: Fork links
Posted: Thu Feb 18, 2010 4:17 pm
by shocky
des wrote:Will these Evergreen fork links work with Li series 3 standard drum hub.
why do you want them? is it for the damper mounts if so PM me
Re: Fork links
Posted: Thu Feb 18, 2010 4:31 pm
by des
A mate is looking to put dampers on his forks, with the weld on brackets on the top and he wants to fit a set of fork links with the damper support studs built in, can these be bought off the shelf or does he need to get his Li fork links adapted to take dampers. He does not want to use the after makets damper support brackets.
Re: Fork links
Posted: Thu Feb 18, 2010 4:40 pm
by Knowledge
Those links will work with a TV SII drum brake.
I'll get my anorak.
Re: Fork links
Posted: Thu Feb 18, 2010 5:01 pm
by corrado
des wrote:A mate is looking to put dampers on his forks, with the weld on brackets on the top and he wants to fit a set of fork links with the damper support studs built in, can these be bought off the shelf or does he need to get his Li fork links adapted to take dampers. He does not want to use the after makets damper support brackets.
MB sell very nice remade drum links with built in damper brackets, they're not cheap but probably cheaper than the ones you posted the picture off. They only work with the GP rods and seperate balls as opposed to the rods with fixed balls that would be std in the Li, they're a straight forward swap though.
Here's a link to MB..
http://www.lambrettaspares.com/sparepar ... 650pr.html
These are the disc links, the drum links don't appear to be on the site (well I couldn't find them), I have stocks if MB are out of stock.
Re: Fork links
Posted: Thu Feb 18, 2010 7:44 pm
by MarkH
Give MB a call. I'm not sure where the drum links disappeared to on their site. The disc links are the best you can get period. Once I started using these, my front end builds have been without issue.
Re: Fork links
Posted: Thu Feb 18, 2010 8:30 pm
by trev t
130365799092
or some thing like this,,,, simples innit
