Fork links
des
Will these Evergreen fork links work with Li series 3 standard drum hub.
no
Stampede
Main scooter: SX200
no, they´re for a disc brake, you have to use the standard fork links for drum brakes... they have a peg on the righthand one, not a slot as those in the picture...
des wrote:Will these Evergreen fork links work with Li series 3 standard drum hub.
why do you want them? is it for the damper mounts if so PM me
des
A mate is looking to put dampers on his forks, with the weld on brackets on the top and he wants to fit a set of fork links with the damper support studs built in, can these be bought off the shelf or does he need to get his Li fork links adapted to take dampers. He does not want to use the after makets damper support brackets.
Knowledge
Those links will work with a TV SII drum brake.
I'll get my anorak.
Martin
des wrote:A mate is looking to put dampers on his forks, with the weld on brackets on the top and he wants to fit a set of fork links with the damper support studs built in, can these be bought off the shelf or does he need to get his Li fork links adapted to take dampers. He does not want to use the after makets damper support brackets.
MB sell very nice remade drum links with built in damper brackets, they're not cheap but probably cheaper than the ones you posted the picture off. They only work with the GP rods and seperate balls as opposed to the rods with fixed balls that would be std in the Li, they're a straight forward swap though.
Here's a link to MB..
http://www.lambrettaspares.com/sparepar ... 650pr.html
These are the disc links, the drum links don't appear to be on the site (well I couldn't find them), I have stocks if MB are out of stock.
MarkH
Give MB a call. I'm not sure where the drum links disappeared to on their site. The disc links are the best you can get period. Once I started using these, my front end builds have been without issue.
trev t
or some thing like this,,,, simples innit
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
