Fork links
Will these Evergreen fork links work with Li series 3 standard drum hub.
- sean brady scooters
- Dealer
no
why do you want them? is it for the damper mounts if so PM medes wrote:Will these Evergreen fork links work with Li series 3 standard drum hub.
A mate is looking to put dampers on his forks, with the weld on brackets on the top and he wants to fit a set of fork links with the damper support studs built in, can these be bought off the shelf or does he need to get his Li fork links adapted to take dampers. He does not want to use the after makets damper support brackets.
- corrado
- Dealer
- Main scooter: Lambretta GP
MB sell very nice remade drum links with built in damper brackets, they're not cheap but probably cheaper than the ones you posted the picture off. They only work with the GP rods and seperate balls as opposed to the rods with fixed balls that would be std in the Li, they're a straight forward swap though.des wrote:A mate is looking to put dampers on his forks, with the weld on brackets on the top and he wants to fit a set of fork links with the damper support studs built in, can these be bought off the shelf or does he need to get his Li fork links adapted to take dampers. He does not want to use the after makets damper support brackets.
Here's a link to MB..
http://www.lambrettaspares.com/sparepar ... 650pr.html
These are the disc links, the drum links don't appear to be on the site (well I couldn't find them), I have stocks if MB are out of stock.
Give MB a call. I'm not sure where the drum links disappeared to on their site. The disc links are the best you can get period. Once I started using these, my front end builds have been without issue.
130365799092
or some thing like this,,,, simples innit
