JL3...
lockman69
As the title says, I have a JL3 ... but what’s the secret with the 2 extended bolts that support the end can?....if there not constantly coming loose and falling out there sheering off.....really starting to p##s me off now...anybody else had and solved this problem.
Cheers
carlos fandango
lockman69 wrote:As the title says, I have a JL3 ... but what’s the secret with the 2 extended bolts that support the end can?....if there not constantly coming loose and falling out there sheering off.....really starting to p##s me off now...anybody else had and solved this problem.
Cheers
Well ive loctited some all thread in instead of the bolts and then a nyloc nut and washer ;)
use a scooter loopy john clamp best you can get imho
joee
mark wrote:use a scooter loopy john clamp best you can get imho
what he said ...
randall ate my dog!!
no one likes us we dont care
lockman69
Thanks lads
hydra
MB's rear support bracket for the Devtour fits the JL spot on and picks up 4 of the chaincase studs, although these have to be changed for longer ones.
cezeta
mine fell apart in iow, i replaced the bolts with longer ones and assembled it with black heat proof gasket sealantm on the threads as well. solid as a rock now.
