As the title says, I have a JL3 ... but what’s the secret with the 2 extended bolts that support the end can?....if there not constantly coming loose and falling out there sheering off.....really starting to p##s me off now...anybody else had and solved this problem.
JL3...
- carlos fandango
Well ive loctited some all thread in instead of the bolts and then a nyloc nut and washerlockman69 wrote:As the title says, I have a JL3 ... but what’s the secret with the 2 extended bolts that support the end can?....if there not constantly coming loose and falling out there sheering off.....really starting to p##s me off now...anybody else had and solved this problem.
use a scooter loopy john clamp best you can get imho
mark wrote:use a scooter loopy john clamp best you can get imho
what he said ...
randall ate my dog!!
no one likes us we dont care
MB's rear support bracket for the Devtour fits the JL spot on and picks up 4 of the chaincase studs, although these have to be changed for longer ones.
mine fell apart in iow, i replaced the bolts with longer ones and assembled it with black heat proof gasket sealantm on the threads as well. solid as a rock now.
