What's the word
Posted: Sat Jan 30, 2010 11:34 am
by red ghost
Re: What's the word
Posted: Sat Jan 30, 2010 11:43 am
by bristolmod
I understand that the ports may need tidying up which is fairly straightforward.
The piston to bore clearance would need checking- if its too tight then that can be sorted by your local reborer. If its too slack then thats another problem!!
For the money and a bit of work seems good value
Never used this "make" but they probably all come from the same factory- I've made up a 200cc one from an old alloy/ steel barrel running 3 thou (old money) and it ran as sweet as a nut with no rattles and no nip ups at all. Good increase in performance and cheap as chips compared with a Muggy etc.
Chris
Re: What's the word
Posted: Sat Jan 30, 2010 11:56 am
by shocky
ive seen the same or similar kits for £90-£100
