What's the word
red ghost
Main scooter: lambretta gp150
What's the word on the street with these kits?
bristolmod
I understand that the ports may need tidying up which is fairly straightforward.
The piston to bore clearance would need checking- if its too tight then that can be sorted by your local reborer. If its too slack then thats another problem!!
For the money and a bit of work seems good value
Never used this "make" but they probably all come from the same factory- I've made up a 200cc one from an old alloy/ steel barrel running 3 thou (old money) and it ran as sweet as a nut with no rattles and no nip ups at all. Good increase in performance and cheap as chips compared with a Muggy etc.
Chris
Scootering since 1968.
ive seen the same or similar kits for £90-£100 ;)
