any one got any ideas or thoughts for this ?
rbgaz
hi all, took scoot out for short ride and was splutering till i got enough revs up and it would clear so thought it was just still cold done another couple miles still doin it so i pulled over and gav it few blips like u do with the throttle to try and clear it , then it sounded like a backfire and dies on me, changed the plug and kicked it over now it fires an runs for 1 or 2 seconds and thats it , pushed it home and swaped and tested stator,flywheel,coil, lead, 5 plugs , 3 caps still same , so now the carb checked petrol flow that was fine carb is filling with fuel , cleaned all jets and they werent blocked , swaped an tested needle an slide, checked choke was going on an off , still same , but i hav noticed excessive vapours coming out of the carb when im trying to start it, but plug isnt really badly wet , so im thinking now hav the reed valves bust or not workin in some way ? your thoughts gents please :(
Dazza
Could it be stale fuel?
ignition /green wires shorting out in handlebars...?
remove green loom wire from coil to isolate and check..
rbgaz
fuel only couple days old, hav tryed removing green wire still same
big end bearing gone .....?
thackers
Have you checked your bulbs to see if they've blown? It could be your regulator, when mine packed in i lost power with the spluttering etc. :?
rbgaz
bulbs fine, if the big end bearing had gone wolud it not sound really bad ie crunching and grinding typs noise ? when it fires for them couple seconds it sounds fine, anyone on here had there reeds mess up ?
startin to lose the will to live lol when it fires into life it dies soon as u try to giv it throttle as if theres no fuel ?
p.s it only backfired the once when it first died, it dosnt do it when it fires up for couple seconds
ok then try this...
pour a couple of CC,s of petrol down the throat of the carb....
if all else is ok ,it should fire up a run for a bit....this would show that the prob maybe fuel supply related.
also ,does compression seem ok,
a dropped ring could be the cause....
rbgaz
k done that still same , looks like theres more coming out the carb than going in just big vapour fuel as if the pertol cant get past the reed block ?
looks like you will just have to strip it then....
but before you do .....just rotate flywheel back and forth by hand.....just to see what you may hear or feel.
