Damper, lower bracket. Location and jig.
Knowledge
Robi sent me a pm, but other might be interested. Well, maybe.
Robi D wrote:hi knowledge,
i saw your posting regarding brazing nuts onto a pair of drum links. i have a set of these and would like to TIG weld on the hardware to make these accept dampers. i recall years ago seeing in scootering that there was a shop that had made up a jig for doing this. my question for you is what did you use to determine the location on the link?
thanks
robi
Rob,
I hope you don't mind me taking your pm and making it into thread on this subject.
Whether others think it was a good idea to braze these damper brackets on or not (to be honest, there haven't been any bad posts, but it seems that people prefer TIG), I thought I would explain how I jigged the lower damper brackets in place.
Rob asked how I decided on the location of the lower brackets, and I was able to do this because I had some bolt-on items that I used for comparision. I hope the photos help you see where they should be locacated.
I intended to use 8mm bolts to secure the bottom of the of my dampers, so I used long M8 nuts, similar to the ones that come on the top of the barrel. You have the slice the bottom of the long nut
Martin
tony
Main scooter: 90ss
I'm sure braising em will be fine-anyone? Only downside would be getting them plated? Can you chrome over the braise?
as far as i know you can.............. :D
tony
Main scooter: 90ss
Martin, yes you can 8-)
Robi D
this is great. thanks again.
red ghost
Main scooter: lambretta gp150
One problem I see is; what's stopping the hooks(where the axel goes thru) from bending outwards during the welding process?
When I go back to work on Monday,I'll bring home the jig I made,might clear the above up.
Knowledge
LG,
I just don't think that it is getting that hot during the brazing process. There is no lateral force on the links during the welding, so it won't bend.
ML
Martin
CPH Lambretta
Main scooter: DL 150 1970
I need some damper lugs welding on to some fork links, is there anybody on here that can help me out?
I don't mind paying for it if someone can help.
Cheers in advance Nick 8-)
Slow is the new fast!
mb were converting them at one point
teamv
Give frank a ring at scooter inavasions ,he did mine we i bought the external spring/ dampers.
    Users browsing this forum: Semrush [Bot] and 70 guests
