lights
rbgaz
hi , can i use a motorcycle battery charger to turn my lights on whilst working on scoot ? if so what wires do i connect charger to ?
cheers
craig69
If your running a electronic ignition, pull off the wire from the rectifier that goes into your loom (not the one coming out the stator) connect the positive to that wire and the negative to a good earth and all the lighting system will work without the engine running.
Asked a similar question a bit back..check my thread out it will answer all your questions matey http://scooterotica.org/forum/viewtopic.php?f=6&t=6805
rbgaz
cheers lads, i know im pretty thick but which one powers up the lights
i hav white,red, two greens ?
craig69
They are your ignition wires on the coil, its the rectifier you are looking for its silver with one wire coming from the stator one from the wiring loom and a earth all plugged into it. Once you have located it just follow the earlier instructions and away you go. :bouncyeng:
rbgaz
lol i get it now , blonde moment lol
