please help am being really thick
davidblythe
I feel i ought to understand these but i dont
MT2 is okay as that is the size of my tailstock
please help a muppet
http://cgi.ebay.co.uk/NEW-Morse-Taper-C ... 439940433d
jimmers
do you want to know if that ok to fit in your tailstock?
davidblythe
jimmers wrote:do you want to know if that ok to fit in your tailstock?
No i know it will do that, what does it do exactly and what do the other measurements mean
jimmers
it looks like a 12mm collet chuck
holds tools and things with a 12mm shaft size in tailstock
on the morse taper
davidblythe
You have to type slowly Jimmers for me :oops:
what is the M10 TAP referring too
jimmers
m10
dont know mate
jimmers
dont use that style
Arch_Stanton
I don't think these are for use in a lathe tailstock, but may fit in your headstock, they are more for milling, drill presses and dividing heads.
Would seem to be a #3 Morse taper with internal 10mm bore, the M12 will be the thread at the rear of the collet into which the draw-bar fits to tighten it.
Bit more info here,
http://www.rdgtools.co.uk/acatalog/2_MO ... LLETS.html
