mb rearsets - anybody got any templates or patterns
caspa2006
hi all.
information on mb's rearsets,
has anybody got or can anybody make me a pattern/template of the back plate
which fits on to the engine side as i would like to make one or can someone make me
one and just mark were the holes go, i can sort you a very good drink out
let me please or email the stuff over with what you would like for them
cheer
del
www.foamwizards.co.uk
get some card or stiff paper ,take off side casing and hold card over exhaust stud holes and push with your finger or pencil over the holes this will give you a pattern for the hole positions ,most rear sets use two long cylinder head nuts on the exhaust studs the monting plate is then bolted to the long nuts ,you will need a break lever pin making with a m8 thread and 13/14mm hex which fixes to the top exhuast stud and use a clutch arm spring for the lever ,hope this is of use
DMC
Ralf Saxelby must have at least 20 brake side back plates of the type he uses on his race bike. Give him a call.
Ian @ MB now clarified situation......
caspa2006
cheers and thanks no hard feeling I hope drunkmonkey
what can i say caspa...
but that your a pain in the arse.
and you have caused us much uneeded trouble and strife...
IF ONLY you could have explained that mark from MB had given you permission in the first place ,all this hassle could have been avoided
granted that there was some unforseen communication probs between mark and ian ,but its basically your lack of initial input and info that has lead to this whole missunderstanding
but i,m glad its all sorted now.... :D
caspa2006
ok mate point taken, but I did say 2 mins. after it was blocked I have premission
anyway time to move on, it a NEW YEAR now :mrgreen:
i agree......onwards and upwards.... ;o)
