dc electrics again.......
minotaur
about to do conversion with a podtronics type regulator etc. etc.
question is .. can i use my agusto retarder with this and will the timing remain the same as my previous ducati set up????
or do i just worry too much???
it doesn't affect the ignition side of the electrics at all.
so, yes you can keep the agusto.
if you're happy with the timing now, mark the stator position before removing it to do the lighting coils wire mod.
are you using an actual Podtronics unit, rather than the Wassell ones ?
be interesting to see how you get on.
We are still waiting for some non-icey roads to test out the recent conversion i did, but I do now think it'll be ok... after all my gloomy posts before christmas...
minotaur
thanks, its not a podtronics it's the single phase norton/bsa one off ebay, the one soulsurfer used, i'll scribe stator position etc. no probs , i just seem to remember reading somewhere that people were getting different timing readings with indian / italian cdi/ rectifiers so just wondered if it made any difference, mechanics i'm ok with , electrics is chinese to me, thanks again
The PODtronics and Wassel are the same, I have one of each. They also work fine with Agusto as Byron says ;-)
soulsurfer wrote:The PODtronics and Wassel are the same
I didn't realise that, i knew they did the same thing, but thought the podtronics must be better at it as it's twice the price! should've known better really
I was told by a British bike parts supplier that he supplies Wassell over PODtronics as they're more reliable. I think the eBay guy is particularly cheap too as I was quoted £35 for Wassell and a POD is around £45, so go figure :? :D
minotaur
thanks again
    Users browsing this forum: Google Adsense [Bot], Semrush [Bot] and 3 guests
