Timing
Bilko
Main scooter: LI150
Couple of things
1. If the flywheel & mag housing have had the circumference reduced does this make a difference when setting the timing?
2. Is it possible to have your own timing mark arrow if the old one is missing?
Bilko's Oily Blog
yes and yes matey. :D
Bilko
Main scooter: LI150
Thanks Sean.
3. Can I put the timing arrow anywhere?
Bilko's Oily Blog
Bilko wrote:Can I put the timing arrow anywhere?
yep, as long as you check TDC and then make your own marks on the mag housing it doesn't matter where the mark on the flywheel is.
Bilko
Main scooter: LI150
Thank you. :)
Bilko's Oily Blog
Bilko
Main scooter: LI150
Next question.
4. If the rotation on the dial gauge is 2mm for 19 degrees. Am I right with 1.65mm for 17 degrees?
Bilko's Oily Blog
Bilko
Main scooter: LI150
1.67 :D Thanks Eden
Bilko's Oily Blog
Bilko
Main scooter: LI150
Something's not right. the two lines are miiiiiiiiiiiiiiiiles out
Edit:
5. I'm trying to understand this. If the lines don't match up and it's so far out. Could the smaller circumference cause this?
Bilko's Oily Blog
firekdp
Changing the circumference of the flywheel, in itself, would not change the timing at all. If it's the lines on the flywheel/pick-up not lining up and you cannot move the stator enough to do so, then either your marks are wrong or your flywheel boss isn't in the correct place.
Dimitrios_231
Just use a timing gun and ignore the pickup lines.
    Users browsing this forum: Google [Bot] and 33 guests
