Rear hub bearing movement.
ArKaTxU
Hi.
When you put the rear hub bearing into the casing, you use some loctite or something similar?
The problem with the bearing, is that i can put in the casing with the hand, without heating the casing, and i can move the bearing with the hand when is inside.
Thanks!
hydra
http://65.213.72.112/tds5/docs/641-EN.pdf" onclick="window.open(this.href);return false;
copy and paste the link
hydra
Some on ebay
