rb225 port map ? Pleeeessee
carlos fandango
Hi
Any one got a RB225 port map the could post up please?
Thanks
carlos fandango
Someone must have one :? :?
Ive got a damaged rb barrel that is 72mm bore but has 2 finger ports like the rb22 not 3 like the rb25 :? so im trying to ascertain if its a prototype 250 0r a bored out 225 :?
so can any one shed any light on it ?
Thanks
Russell
i,m sure dan did one a while ago...try a seach. failing that look on old forum .
carlos fandango
Hi Sean
yes ive tried that and got the rb20 and rb25 but cant find the rb22 :?
spigot size on RB22 is 75mm
bore is 70m,and so spigot thickness is approx 2.5mm
carlos fandango
Well that the other odd thing the spigot is 78mm (so 3mm wall) and not stepped like the other 250s ive seen
Ive found a port map now.... and it has the same layout as a 225 :?
I should of said..... its unused aswell with a broken spigot ?
johnd
Main scooter: 1970 Dl125
I dropped My RB kit when i first got it and bent the spigot, but after i'd stopped screaming and crying i got out the dremel and got my mate (my hands were still shaking from dropping it) to remove the bent bit of the spigot. We did this progressively so as not to take more than we needed away.
Its been in the scooter now for around 2500klms now with no problems.
rossi46
Here ya go
carlos fandango
Thanks rossi
i had managed to find it but thanks anyway
Russ
