LI side panels
surènos
i got a 66 li with clip on panels that i would like 2 put 150special panels on do all the special panels have handle fittiings & is it poss 2 fit em on a frame wiv clip on types by changing all the fittings plate etc
as long as you fit the handle type hooks all will be fine
sun130
Just to answer your other question surènos, the very late SX150's were fitted with non handle 'clip on' 'special' side panels along with other unique items leading up to the introduction of the GP range.
I would have thought that 66 was a little early for clip on panels on an LI !!
surènos
thanks 4 the tips i didnt know 66 was early 4 clip on types they mustve been changed by sumbody already then which makes me feel betta about changin em bac what year did they start using clip on types
mawso
My D reg 66 LI3 had clip on panels and a plastic toolbox...but not the rectangle Innocenti horncast badge of the LI4. Mine was June 66. I don't know when the LI3 ceased and the shortlived LI4 went into production, which definately did have clip on panels.
I was thinking that. What sort of horncast do you have?
surènos
its got the same li horncast as most series 3 the same as on say a jet 200,so from reading above the clip on panels could be the standard ones
Ah, it's a Spanish machine is it? Most probably it is right then.
goldeneye
i think his name maybe gave it away it might be spanish. not many surenos"s in easington colliery. couple in blackhall though :lol:
goldeneye
late SX200"s had clip on sidepanels as well. and square horncast badge, plastic tool box, clip in fork buffers etc. one in our club, "F"regd. spanish plain LI panels are slightly fatter than italian ones as well. i think the "knuckle duster" type may be a bit fatter, but cant remember now. :?
