dragster engine
vesbrettas
hello there just wanted to know if any body can help me. i striped the clutch any variator out of my dragster about a year ago and put all the bits safely on the side then my misus decided to knock everything over. now its been a while and was just checking if there should be a washer between the variator and the water pump pulley on the crank as i cant find any good diagrams about
any help would be much appriciated
cheers Dan
e type
[quote="vesbrettas"]was just checking if there should be a washer between the variator and the water pump pulley on the crank as i cant find any good diagrams about
no dont think so hope this helps
Best asking on http://www.scooter-scene.co.uk quite a few into dragsters and I'm sure some one could answer this for you
Just click the fourum tab :-)
C*NTSPEED
vesbrettas wrote:hello there just wanted to know if any body can help me. i striped the clutch any variator out of my dragster about a year ago and put all the bits safely on the side then my misus decided to knock everything over. now its been a while and was just checking if there should be a washer between the variator and the water pump pulley on the crank as i cant find any good diagrams about
cheers Dan
is it a standerd variator if so then no but if polini or malossi they both have a 4mm washer that fits on the crank before the variator backplate
then...
the gap is the flypully half ;)
GEMINI S.C.
BLACK WIDDA'S S.C.
    Users browsing this forum: No registered users and 55 guests
