Serveta Jet 200
cranky
What is the largest carb I can fit to a Serveta Jet 200 keeping the standard air box and sidepanel ?
A bit silly I know - but I want to keep the scooter looking as standard as possible............
some thing like a 30mm phbh delorto but that would also depend on what tune /kit / exhaust etc
cranky
Bog standard (for now !) - will probably want to fit an AF reverse cone , Ancillotti big bore or AF big bore pipe at a later date.
Breathing through the airbox? I'd of thought anything above 26 mm would stuggle to get enough air?
ArmandTanzarian
I'm not sure I'd bother to go any bigger than a 24mm. The airbox is too restictive for anything much more.
I run a Mikuni 24 with a foam airfilter; goes well, doesn't guzzle fuel and starts easily.
cranky
My thought exactly Corrado and after thinking about it Armand's suggestion seems more practical !
