hydraulic master cylinder on series 2 head set
M210
Have to mount my hydraulic master cylinder (LTH anti dive) to my S2 head set.
Is there any supplier who sells such stuff?
Only know the S3/MB connectors but didnt see pictures of a hydraulic master cylinder mounted to a series 2 before.
Who can help? Any pics? Any other topics in the past I didnt find?
Did find this picture from Mike´s S1 right now. Is this a self made housing? If not - where to buy?
scootRS.com
LTH does, don't they? Did you ask them?
What MC do you have? If you have one from them it will likely be cut a certain way so you need the matching mount cut the same way. Unless it is not modified at all yet?
If you have a Nissin type MC (or Chinese copy), you can get one of our supports or even a copy from a few places but you're likely going to have to do some work to make it fit, modified or not. Even the copies won't swap with ours without modifying them as they seem to be cut all differently.
Here's our latest, flush-mounted, sleeker, all types interchangeable:
L4Lambretta
While were on the topic. How do i fit one to my series 1? I've got a SCOOTRS master cylinder assembly, does anything need to be modified.
cheers
L
