Page 1 of 2
series 1 hidden master cylinder
Posted: Sun Nov 08, 2009 10:51 am
by cezeta
im looking to fit a hidden master cylinder to a series 1 as i dont think the s1 will look too tidy with a cortina servo strapped to the bars.
has anyone used the gremica master cylinder, if so where did it fit? under the horn cast?
Re: series 1 hidden master cylinder
Posted: Sun Nov 08, 2009 9:40 pm
by cezeta
thanks for the offers but i already have the master cylinder i just need parantal guidance about if it will fit under the horn cast and where is the proven place
Posted: Sun Nov 08, 2009 10:44 pm
by Train Driver
What about inside the legshield and if you fit your mini legshield toolbox put it in there
Posted: Sun Nov 08, 2009 10:58 pm
by cezeta
crap idea award goes to.....
Posted: Sun Nov 08, 2009 11:11 pm
by mark
talk to replay bout this as was there last week and they have done one
Posted: Sun Nov 08, 2009 11:13 pm
by paulc
got one fitted to just above the horn behind the horn casing. a load of wank .apparently you gotta make sure the bracket you fit is rock solid or the whole thing flexes, getting rid of it & fitting the normal light switch housing type till something better comes along
Posted: Sun Nov 08, 2009 11:20 pm
by burridge01
Mines fitted under the horncast,JB Tuning did it,works a treat.Would take a pic for you but scooters at the sprayers.Might be worth giving them a call.
Posted: Sun Nov 08, 2009 11:37 pm
by J1MS
I did my own conversion to Two of mine, and a few of my mates scooters, all have worked well up to now. I fitted them behind the horncast (welded a bracket on, not bolted)...
Posted: Sun Nov 08, 2009 11:42 pm
by cezeta
ok thanks fellas, just wanted to make sure there was space before venturing out into the cold. my second option was to use a px gremica master cylinder as its the most descrete once polished up the same as the switch housing but ill try the hidden one first
Posted: Sun Nov 08, 2009 11:44 pm
by cezeta
mark wrote:talk to replay bout this as was there last week and they have done one
is your dac engine the one in chrome powder coating?
