HUBS
jet fraser
LI125 SERIES TWO FRONT HUB AND SERIES TWO TV175 FRONT HUB... WHATS THE DIFFERENCES?? SAME GOES FOR AIR BOX CHEERS
Supereibar
Both hubs need different fork links to beguin with. The 125/150 SI/SII hub has an incision shaped like a "U" in the backplate, which helds the "male" on the right fork link.
On the other hand, the TV1/2 hub, has a stud coming out of the backplate, this backplate holds the "U" at the right fork link.
Different hubs which needs different fork links.
J.
Supereibar
Forgot, the airbox is pretty much the same on both TV2 and Li125 Series II. THe thing that changes is the neck and the air intake, which are considerably bigger on the 175 Series 2, which has if I am not mistaken a 23mm carburettor...
