62mm or 64mm piston
AUSSIE
Does anyone know of a 62mm or 64mm piston that has the ring pegs running each side of the exhaust port? I have a reed valved 175 with an extra boost port cut into the intake side, at the moment i am using an asso piston but one of the pegs lines up with this port so I can only use 1 ring.
The piston out of the GT185 kit doesnt fit as ring pegs are in a similar area as the asso.
Knowledge
The Suzuki TS185 pistons (64mm) have ring pegs in different locations through it's range of models. I think that the TS185ER piston (P/N 12010-29900) has them furthest apart, but they are still on the inlet side.
You might get lucky, but it does prove the value of planning where you cut boost ports. I appreciate that it is often easier said than done, and on occasions when I have done piston swaps, I have just got lucky.
Martin
jonny snatchsniffer
some jap stuff runs ring ends over ports, even some of the wiseco pistons have the peg directly opposite the exhaust where there is almost certainly a port, its just a matter of how wide the port is and how much of the end protrudes into it
grimspeed
Main scooter: gp 283 kx
try suzuki ep 175 =62mm same as er-ts 185 just smaller
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
