gear selector arm stud?
mickdale
anyone know where i can get the small conversion stud for a gp gear selector arm that i want to drill and tap out?
cheers
mick
mickyb
just get some 5mm bar, weld or braze it in, then cut a 5mm thread on stud to take a nut.
lamblast
rear hub bearing stud is the one i use
mickdale
thanks
mick
Is it possible just to use a small bolt, say 10 / 12 mm from beneath then grind down the head for clearance?
