Further woes (electric)
Posted: Thu Jan 22, 2009 6:00 pm
Some of you may remember on the old forum I had some electrical problems with one of my scoots. Basically all lights including brake are not working.
I have replaced the stator for a 120 WATT BGM and swapped the Regulator and ignition switch for known good ones.
All wiring and earths checked and double checked.
I am getting around 15 volts at the brown in the headset, but if a connect a lamp across it, it does not illuminate. However, if I put the lamp across the yellow from the stator it does light up.
So the brown seems to be breaking down under load.
Any Ideas?
Any Ideas?
