Old Af Stator With New Indian Flywheel?
Posted: Fri Oct 23, 2009 10:06 pm
Can I use an old Af electronic stator with a newish Indian electronic flywheel. If I was to try to use this stator am I right in thinking that there is some mod required to the mag housing? Was it something like having to have it machined out by 1mm to let the stator sit back slightly? Was it just because the stator bolt heads where too high and hit the flywheel so could I just use the shallower headed bolts?
