Tuned SR175 22mm Jetting?
eadmr04
Just fitted a SR175 top end which has had quite a bit of work done on the ports and transfers. I'm running with a 22mm dellorto and 42mm clubman. I started with a 125 main and have moved up to a 128 but it still is not feeling boggy when you open right up. The next step is to try a 130 and possibly a 132 main. Does this sound about right as I thought this would have been too large but it seems to pull cleanly all the way until it's flat out? Would this be because of the porting and transfer shaping and should I just keep going up till it starts to get boggy on the main?
eadmr04
Forgot to say, everything else is standard 200 jetting/carb.
