Lambretta Rapido 225 - what carbs are you using?
adriang
I'm running a 225 rapido on my GP. Currently using a PWK, but I've never got it really dialled in well, as is seems to be flat mid range. Currently running a B-Race Stealth exhaust and no air filter.
Thinking of other options, and I'm interested to know who else out there is running a Rapido 225, and what carb you're using and any details you can share on set up (of the carb and/or exhaust and other bits and pieces).
thanks in advance.
cezeta
mikuni tm24 or 30 are popular. the stealth will probably want a bigger carb than the 24mm so 27 or 30 mm mikuni with a cambridge lambretta breath easy filter.
whats the stealth revving to on the rapido?
