steering lock removal / replacement
Posted: Mon Oct 12, 2009 3:58 pm
by joda
i have no key for the steering lock on the jet, how easy are they to remove and replace?
any recomendations on where to buy a replacement from?
Re: steering lock removal / replacement
Posted: Mon Oct 12, 2009 5:21 pm
by leigh
Small locating screw inside of headset, remove and the lock will come out. as for replacement most dealers would have i should imagine.
Leigh
Posted: Mon Oct 12, 2009 9:28 pm
by rog60
leigh wrote:Small locating screw inside of headset, remove and the lock will come out. as for replacement most dealers would have i should imagine.
Leigh
Also lock tongue is located under a small round alloy blanking plate which needs to be prised out. When the lock mecanism is being removed, there will be a small spring and plunger underneath. Remove carefully as can fall down inside the horncast/ legshield gap. Replacements are available often as a complete kit.
Posted: Tue Oct 13, 2009 12:42 am
by corrado
For S3 / GP Indian ones are about a fiver, Italian about £15. I've got both plus the screw, plunger, spring and cap.
Sometimes they're a barsteward to remove without having a key to use to pull it out.
Posted: Tue Oct 13, 2009 9:15 am
by joda
thanks for all replys, will have a look tomoro night and see what i can do!
corrado you have pm rearding the lock!
