hydraulic fluid gone?
druist
Due to various probs other than scooters i havent used mine much this year, the other day i noticed the front outboard brake seemed to easy to pull, opened up the reservior and low and behold no fluid - this is one of the superfly ones with the braided cable, how should i proceed, obviously there is a leak and perhaps at one of the joins but flushing out the residual fluid???
As what worries me there must be some evapouration occured by now, do you just flush with DOT4 and fill again once leak is found or what????
