64mm stroke crankS??
RinB
gonzo wrote:hi, im after a 62 or 64mm crank wot options are there? they seem to be hard to get hold of and crazy money!!? :shock:
Im afraid youve hit it on the nail:?
Try MB's, Tino, Chissels, JB's , Taffy's
I'm intrigued....why isnt there a 62mm or 64mm option readily available?
And as for the companies listed....any ideas what BHP each can handle?
paulj
drunkmunkey6969 wrote:I'm intrigued....why isnt there a 62mm or 64mm option readily available?
does anyone know what the "evergreen" cranks are like from scootercenter? they list a 62 and 64 stroke crank at quite good prices, but they are hardly ever in stock.
paul
joespeed
paul
dan the reason why they are not easily available is because there is quite a bit of welding and machining to be done and not a job for the average man in the shed!
regards
joe
Note from Mark @ MBD:
Our 62mm fits with no welding but needs a cutout doing for the con rod, and our 64mm fits with no welding but the casing needs boring out to the diameter of the mag housing then some fine tweaking around the mag gasket face to slide it in.
My Carbon bike for the IOM 100th was 37 bhp, with no problems.
I only sell 64mm cranks to customers engines.
deany
Message from John @ JB Tuning:
''We have our own range of crankshafts, 58, 60, 61 and 62mm. These come with your choice of conrod, 107, yam 110 or 115mm.''
''For 62mm you will need to machine a space for the rod, but we can do this for you.''
Prices and stock can be seen on the new shop site:
http://www.jbtuningshop.com
(updated daily)
thanks, hope this helps
Great info, nice one. 8-)
    Users browsing this forum: Baidu [Spider] and 6 guests
