Gearbox cluster bearing track.
Posted: Thu Oct 01, 2009 8:21 pm
by Ihateyoubutler
Anyone know where I can get the gearbox cluster bottom bearing surface machined and a track fitted? (As in Sticky's book).It's pretty corroded, but does it really matter anyway?
Don't know really if it's worth the cost or just wait to see if I can find one.
(Italian gp 125 if anyone has one for sale?)
Thanks.
Re: Gearbox cluster bearing track.
Posted: Thu Oct 01, 2009 9:13 pm
by Tosh
Ihateyoubutler wrote:Anyone know where I can get the gearbox cluster bottom bearing surface machined and a track fitted? (As in Sticky's book).It's pretty corroded, but does it really matter anyway?
Thanks.
av you tried jem booth at wesham in lancashire is adverts in stickey man his phone number is 07866272130/01772495577 its worth a try
Posted: Thu Oct 01, 2009 9:25 pm
by byron
I bought one from Jem's stall at last wicksteed.
think Scooter Restorations stock them too
bitch to get the old one out though
Posted: Fri Oct 02, 2009 9:05 am
by Ihateyoubutler
Thanks for the replies.Don't think I've explained it properly.It's the bearing surface on the cluster itself which is shot.This needs machining down and a new track (same size as origonal bearing surface) fitting on (like a mag side crank bearing).
Thanks.
Posted: Fri Oct 02, 2009 9:50 am
by leigh
Think MB do that. Also think they sell the part so you could get local engineer to machine Xmas tree and fit.
Leigh
http://www.lambrettaspares.com/sparepar ... b0042.html
Posted: Fri Oct 02, 2009 10:14 am
by soullad
don't you just machine the cluster and fit a thicker track in the casings to match?
GP 125 is the same as gp200 anyway so probably easier to simply get new cluster? Its that time v. money thing all over again
Posted: Fri Oct 02, 2009 12:20 pm
by J1MS
Lambretta used a tool for removing the track. Which a similar item was available from MachineMart about ten years ago, not sure if the still sell it.
But if you get a bar machined to the diameter of the track so it's a tight slide fit, heat the case by the track then just over half fill the bearing track with high melting point grease, place the piece of steel in the hole center it up & give it a sharp tap the track should rise out of it's seating slightly because of the pressure.
Otherwise dremmel through one side carefully then pull out.
Posted: Fri Oct 02, 2009 6:25 pm
by Ihateyoubutler
I think thats exactly what I need, thanks. The link doesn't work for me, but I'll ring them.
Sorry again about the poor explanation of what I needed, it's on page 56 of Stick'y book, bottom left of page (the cluster/xmas tree itself).
Thanks again for all the replies.
Posted: Sat Oct 03, 2009 11:32 am
by leigh
Posted: Sat Oct 03, 2009 12:58 pm
by Ihateyoubutler
Thanks Leigh.
