Basic engine info please
Posted: Mon Jan 19, 2009 5:23 pm
by TS1-200
Rebuilding a S2 LI 150,it has the later mag flange bearing and oilseal arrangement, but there is no oil thrower washer behind the front sprocket cush drive, is this normal for a series 2 case?, would an oil thrower washer fit ? in any event it would be better to fit the driveside bearing with the integral oil seal I guess,any ideas.?
Re: Basic engine info please
Posted: Tue Jan 20, 2009 12:12 am
by Knowledge
It sounds like you have a SI engine casing. These did not have a dished oil thrower, and one cannot be fitted.
It is always better to fit the bearings with the integral oil seal (remove the oil seal on the side that will be lubricated by the gearbox oil).
Posted: Tue Jan 20, 2009 1:02 am
by TS1-200
Yes,thats what I found out, I`ll fit the the sealed D/S bearing with chain side removed.
Posted: Tue Jan 20, 2009 4:41 am
by corrado
I think the 1st batch of S2 were the same.
Posted: Tue Jan 20, 2009 2:47 pm
by 156 D
I don`t know if it was just missing ...but in 1964 my mates 1960 Series 2 TV175 didn`t have one either....his TV was bought off an old boy then, who just poodled about town....it had all it`s servicing done during those four yrs. at Frank Bannisters garage at Chatham....so it should of been an original feature?...not being there i mean....
Posted: Tue Jan 20, 2009 10:04 pm
by sideout
Sounds common on early S2 TVs, my mate has one without an oil thrower too
Posted: Tue Jan 20, 2009 11:01 pm
by TS1-200
Just out of interest, exactly what purpose does the oil thrower washer serve, I assume it helps keep gearbox oil away from the drive side bearing oilseal, obviously Innocenti in their development must have decided that it was a possible weak spot.
Posted: Wed Jan 21, 2009 4:57 pm
by shocky
i thought the oil throw ring was there to help oil that is splashed around that area to enter
the bearing the oil slids down the inside of the casing and enters the V shaped gap that the casing and the washer make then flows into the bearing maybe im wrong
Posted: Thu Jan 22, 2009 12:51 am
by TS1-200
