scorpion pipe
oggy
Going to change pipe from sx 200 barrel to my hb175 barrel will it fit straight on as im having problems with the mounting bracket sitting to far from the 2 studs also the rear shock mounting is sitting to far out???. Am i wasting my time. :(
oggy
anybody? or is it clicky? :biggrin:
Ricko
Would have thought someone would have responded to your posting before now.
I would have thought it should have swopped over fine between the same series (slimline scoot), but would need working/adjustment if swopping from another.
My advice would be to fit with all mounts loose, in order to gain the best fit, then tighten up fitting when the exhaust is on.
Cheers Rick.
P.S. bet others will post now...........i'ts a bit like buses stand waiting and they all come along together! :biggrin:
oggy
Will do , thanks for your advice.
