what spokets required 4 gp 200 gear box
no-hair
what spokets r required with gp 200 gearbox to give top end speed , more than pulling away power , :bouncyeng:
RinB
no-hair wrote:what spokets r required with gp 200 gearbox to give top end speed , more than pulling away power , :bouncyeng:
Whats your set up ie Barrel carb exhaust ect
bigger front one smaller on the clutch, if you engine is capable of pulling it a 19t will fit if the chain has enough slack if your on the large side or struggle into winds or on hills i wouldnt bother
no-hair
indian stage4 200 with indian clubman , cheers :bouncyeng:
rog60
Main scooter: Indian GP200
The following do work as I have used them:-
19 x 47 (needs stretched 82 link or 81 link chain)
19 x 46 (82 link chain)
